D0OB battery heatshield
Discussion in 'General Maverick/Comet' started by 9464larry, Oct 31, 2016.
  1. 9464larry
    9464larry Member
    aspers,pa
    71 torino
    I am currently reproducing the hard to find D0OB battery heatshield,this fits 70-71 torino,cyclone 70-73 mustang,cougar,most often with 351c and larger or performance engines. This is typical with other ford battery heatshields in that is is molded in plastic but is unique as to dimensions,battery position, ect. from other heatshields. They almost all meet their fate upon the first battery change,getting tossed in the trash making them a prized part among concourse restorations
    My question to the maverick/comet community is " was this part ever used on this car line?" I thought that I seen something on here that referenced it being so? I do not know but would like your input. thanks Larry H
  2. Acornridgeman
    Wisconsin
    Hi Larry,
    These cars didn't have that from the factory that I have seen. It was just the battery mounted to the tray - no shield like the Mustang used for some engines.
  3. rthomas771
    I'm no expert on this subject but I do see D4DZ 10A682-A listed as "SHIELD (BATTERY HEAT)" in the 73-79 Ford Master Parts catalog for the 74-77 Maverick with 302. The 65-73 catalog doesn't list this for a Maverick. The 65-72 Lincoln-Mercury catalog list a DOVY 10A682-A (plastic) and 73-79 list the D5VY 1OA682-A (plastic - 2 sides). As you know...sometimes the only difference in the part is the part number and sometimes the part is a different animal.
    Thanks for stepping up to the plate making a new part for the car hobby.
  4. Acornridgeman
    Wisconsin
    Jeff I wonder if it was in the master catalog to allow dealers to add it if they had a customer with heat issues. As I posted earlier - never seen one on a factory car and I don't remember ever seeing one back in the day when I worked on these cars daily.
  5. 9464larry
    9464larry Member
    aspers,pa
    71 torino
    I am familiar with the D4DB shield it is almost a direct match for the D0OB only it is about 3/8 shorter,I believe this is because the motorcraft battery was different dimension than the autolite but that is a assumption. The D4DB shield has been used for a long time in substitution for the D0OB, believe it was found in granada's and monarch's
  6. Craig Selvey
    I seem to recall only ever seeing ONE on a car, as I still have it. I feel pretty confident that a Maverick had one.
    BKelley likes this.
  7. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  8. 9464larry
    9464larry Member
    aspers,pa
    71 torino
    Craig,are you saying the one you seen was the D4 or the D0 ? what year was the V-8 first available for the maverick
  9. Acornridgeman
    Wisconsin
    1971
  10. Craig Selvey
    1974. I will post some pictures.
  11. Craig Selvey
    Here are the pictures. This was on a 1974 Grabber V-8.
  12. mojo
    How is the shield fastened down, don't see any mounting points on it?
  13. Acornridgeman
    Wisconsin
    They just fit around the 2 sides of the battery and stay in place without fasteners. The tray along with the hold down J bolt keep it from falling out.
    Craig Selvey likes this.
  14. CaptainComet
    You would think this would be more common in Southern states, with a warmer climate, but I don't recall ever seeing one back in the day.
