Damn Column Shift
Discussion in 'Technical' started by Mr Nick, Jan 6, 2015.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    So my column shift has decided to start slipping into Reverse when I try to park (which'll fail an inspection). My question is, where do I go next? Should I replace the bearings or search for a new shaft to gut for a certain part? Does anyone have a shaft they'd be willing to get rid of if that's the case?
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Have you checked the linkage? It may just need adjusted so it can engage the detent in the column.
  3. 71gold
    :yup:...sounds like an adjustment needs to be made to the linkage.
  4. Craig Selvey
    It is the linkage.....or....your bushings on the linkage parts.
  5. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Yep, sure sounds like worn out bushings to me.
  6. Mr Nick
    Grapevine, Texas
    Bushings in the column or linkage? I just tightened the linkage when I did my trans filter though :90:
  7. RMiller
    Kennewick, WA
    The bushings are in the linkage, about the only thing inside the column that could be an issue is the detent or the point on the end of the shift lever which is pretty unlikely. The adjustment should be at the bottom of the rod coming off the column.
  8. Craig Selvey
    As stated...the bushings in the linkage.
    I would start with checking the adjustment where the rod connects to the trans.
  9. Mr Nick
    Grapevine, Texas
    So this bushing in the middle?
  10. Craig Selvey
    All the black bushings for all the linkage pieces from the column down to the trans. They look pretty good in that picture.
  11. Mr Nick
    Grapevine, Texas
    Oh boy.
    Well it's too cold to creep under there tonight. Will post a pic of the linkage tomorrow or whenever it's nice outside.
  12. Mr Nick
    Grapevine, Texas
    Pic related
  13. Craig Selvey
    Looks like the nut was in a different spot on the linkage before....so it probably needs to be readjusted.
    rthomas771 likes this.
  14. rthomas771
    What Craig said :yup:
  15. Mel Moeller
    Twin Falls Idaho
    What Craig & Jeff said. :rofl2:
