Damper question
Discussion in 'Technical' started by 72true62D, Dec 28, 2008.
  1. 72true62D
    72true62D Dont Talk To Me Like That
    Bradenton Beach, Fl.
    72 maverick Grabber 302, 66 Mustang 351w
    Will a 4 bolt damper from a 1972 351w swap out with a 3 bolt damper in a 1968 302?:huh: Thanks, Jeff
  2. PaulS
    It will fit the crankshaft but it might be thicker which will put the crank pulley out front more unless you can find a pulley that has less off-set.
