dash lights
Discussion in 'Technical' started by cwspark, Apr 16, 2005.
  1. cwspark
    cwspark New Member
    Kelso, WA
    1975 maverick 2 door /ford cobra
    my dash lights are real dim and won't adjust, also the turn signals work but very very slow i have replaced the blinker. no help
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Check out posts on this site regarding the 2825 bulb upgrade for the dash lights. Also if they don't adjust with the dimmer you probably have a bad headlight switch.
    There are 2 flashers on the car one for the emergency flashers and the other for the turn signals you probably swapped the wrong one.
  3. Jamie Miles
    Yep, I bet you swapped the emergency flasher. The turnsignal flasher is on the back of the insturment cluster.
    Our Mav had the same problem with the signals when we got it.
  4. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Also a very good chance your charging system has low output.
