Dash pad removal
Discussion in 'Technical' started by ray, Oct 27, 2012.
  1. ray
    ray Member
    portland
    71 grabber
    When removing a nice dashpad at my local wrecking yard i removed all the nuts i could see, it would not cone off i discovered there are three nuts on the front leading edge you cannot see also there's one on each end hard to see but loosining the dash bottom was able to pull it up enough to remove them.
