..dash pad repair...
Discussion in 'Cosmetic' started by 71gold, Jan 21, 2013.
  1. 71gold
    I have a dash pad that the metal underside had rusted "completely away".
    I had another one that the top pad was "missing", the metal underside has no rust at all.
    I am trying to come up with a product that will stick these two surfaces back together...:yup:
    they look to have been...heat sealed/molded together...in the manufacturing process...
    mating...foam to metal...
    thanks for any, probably not all suggestions...
    Frank...:Handshake
  2. mercgt73
    mercgt73 Member
  3. Dave B
    Panel adhesive?
  4. 71gold
    that's a whole lot of glue for one project, but...:Handshake
  5. 71gold
    can't see any that works with foam, just (metal...fiberglass parts) hard parts...:Handshake
  6. 71gold
    pics.
    pad back is real porous...:yup:
  7. blugene
    Use a cap and use instant foam to make a new pad that just needs a vinyl wrap.. :huh:
  8. Dave B
    It'll glue anything.
  9. Moneymaker 1
    Panama City Florida
    Liquid Nails.
  10. 71gold
    would you suggest the...Liquid Nails...that's to be used on Styrofoam.
    ...Frank...
  11. Moneymaker 1
    Panama City Florida
    I have used Liquid Nails on everything and it works well, if they make one for styrofoam it should work, but I have been thinking about this today and thought, why not use just a bit of the expanding filler foam in the can from a hardware store, that will fill the holes a bit in the foam rubber and grip it, and will also stick very well to the metal, just dont put too much on it.
  12. Craig Selvey
    They do. It's used to glue styrofoam insulation to the foundation. Should work on metal.
  13. 71gold
    ...I know some will melt Styrofoam...:Handshake
  14. Dave B
    Do you have blue styrofoam insulation in the US? Around here they do, and they actually have blue glue.
  15. groberts101
    groberts101 Member
    Minneapolis, MN
    that's right.. some versions can.
    I also think the expanding foam would also work well too since it also has pretty decent adhesive qualities. And I know it sure doesn't come off any eaiser than liquid nails since I use both in construction projects and ruin clothes with both products more than I care to admit.
