Is there anyone out that has replaced the dash in there Maverick? I removed all of my bolts and started to pull the dash to me with know avail are there clips that this dash sits on or are there bolts up near front window that I should be checkingf for.
Yes....there are bolts up under the rubber window gasket. Do a search...it will tell you to remove the windshield.
http://mmb.maverick.to/search.php?searchid=442829 Read these posts...there are several that should have the info you need.
Hello Libby H, If you click on the technical thread and type in Dash Replacement you will find some information there. I don't know to what degree of replacement you want to do, but it says you have to remove your front window to replace the dash. Let me know what you find. Tony
If I can get a photo to post with my reply, these bolts may be the ones that you are looking for. Yes, windshield has to be removed.
