Dashboard or Steering Column
Discussion in 'General Maverick/Comet' started by alaskamaverick, Jul 20, 2013.
  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    Any recommendation on what to install first? :huh:
  2. 71GTComet
    71GTComet Member
    Atlanta, GA
    1971 Comet GT(Sold) 1985 Ford SSP LTD
    Either way you'll have your work cut out for you. Are you installing the column with or without the steering wheel?
  3. alaskamaverick
    Spokane, WA
    The steering wheel is currently off of the column, was thinking of waiting to install the steering wheel after...so i have more clearance
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Dash first, there is a bolt that goes through the brake pedal bracket into the dash that is above the column.....
  5. rthomas771
    I put the steering column in first. Steering wheel last.
  6. alaskamaverick
    Spokane, WA
    1 for dash and 1 for steering column...tie breaker anybody?
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I usually go dash first, column is a pain any way you go unless you're a contortionist.
  8. Craig Selvey
    I would vote dash first.
  9. alaskamaverick
    Spokane, WA
    dashboard it is..thank you for the input...wish me luck
  10. alaskamaverick
    Spokane, WA
    I GOT THEM INSTALLED :thumbs2:
    Thanks for the help/input guys
  11. mav1970
    I can tell that is a 70 looking at that small tunnel - what color orange are you using?
  12. alaskamaverick
    Spokane, WA
    Yep it's a 70, good eye! It's suppose to be the original thanks-a-vermillion red...i think it's more orange though. DuPont 4602
  13. mav1970
    It looks a lot like the 69 Camaro Hugger Orange that I am using on my 70:)
  14. 55crownvic
    55crownvic Member
    colorado springs
    Thats a no brainer....dash first, no column in the way...then the column, as one person stated allready, there is a bolt that goes up thru the dash where the column would be. Dash then column. Columns are simple, specially if you have the wheel off.
