Datsun wheels?
Discussion in 'Technical' started by AppMaverick, Dec 13, 2009.
  1. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    COOL!!!!!! Some of those are killer looking!
  3. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    yea. I was thinking about getting one of the sets. Is offset the same as backspacing? any other quirks as far as sizing goes that I should ask them when I call that you can think of?
  4. Acornridgeman
    Wisconsin
    They fit our 4 lug cars perfectly. In fact, the classic Datsun slots are often made by US Indy. :thumbs2:
  5. PAINTANK
    1973 Comet 2 dr
    So everyone can have slotted mags!
  6. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    brad:)
  7. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    so not to get too far off topic, but did you lower your car at all? mine is riding about the same height as the one in the pic with spring clamps on it. Debating my options, thinking maybe cutting.
  8. bradleygt
    bradleygt Member
    1970 maverick
    no no engine in it at that time
    did you tighten your control arms with them hanging? if so try loosing all you control arm bolts maybe that will drop it down?
    brad:)
  9. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    whoa.. loosen my upper control arm bolts? I have them torqued to manufacturer spec. The problem I have is that advanced auto has springs for a mav with AC that are 1.3 inches longer than the springs for no AC... now I gotta figure out how to drop it. thinking cutting would be easy (351 would be fun haha). I'll figure it out. Thnx for the reply.
  10. rthomas771
    Your springs came with 1414 pounds load rate at 15-7/8" free height with 8-3/4 coils... You AZ springs should be 1470 pounds load rate at 16-1/8" free height with 9-1/8 coils. The free height has nothing to do with ride height.
    You should toque the suspension when the car is sitting on the ground...not while on jack stands.
    Do not use a torch to cut coils...the heat will destroy them. Use a hack saw or go slow with a cutting wheel to keep the heat down
  11. bradleygt
    bradleygt Member
    1970 maverick
    X2
    brad:)
