Dave, I found it.
Discussion in 'Other Automotive Tech & Talk' started by blugene, Nov 9, 2009.
  1. blugene
    I looked for the thread where we discused the VIN being under the fender where it bolts to and I couldn't find it. I took one fender off so far today and found it. Should that area have a bend in it? Should I flatten it? I also found some other intresting things.
      File size:
      27.7 KB
      188
      File size:
      22.6 KB
      189
  2. 1973Maverick357
    Cookeville TN
  3. Mavman72
  4. blugene
  5. Jamie Miles
    The bottom VIN appears to have been done with a different set of punches, the numbers are slightly different, plus unevenly spaced, my guess is that it wasn't done at the factory like the top VIN. Which VIN matches your car? Very interesting.
  6. mean_maverick
    wow... never seen anything like that before
  7. blugene
    Same on the other side! I will look at the VIN on the tag after dinner and see which matches.
  8. blugene
    This is on the blue tag on the door opening.
    Body Color Trim DSO
    62B 5L LF 22
    3K31F508145
    Where is 22?
    Looks like the 31F is missing from one of the #'s. :huh:
  9. Dave B
    Ford quality..anything was possible back then, someone probably made a mistake, either before or after lunch. kinda neat thought.
  10. 1973Maverick357
    Cookeville TN
    That 31F wont be part of the vin on the fender. So the bottom one is the one on your door what about the dash? does it look tampered with. Looks like the 2nd Stamping isnt as legit as the first stamp.
  11. Rando76
    Rando76 Member
    Claremore, OK
    Looks like you had a friend living in there as well. :rofl:
  12. blugene
    Not sure what you mean by second stamping.
    My dash was tampered with!! :16suspect
    :rolleyes:
    I put the tag in a 72 dash. That partial drill hole was already there. I reused the drilled holes.
  13. blugene
    I thought the same as you but it looks installed lol.
