De Frost
Discussion in 'Technical' started by streetrod77, Aug 16, 2006.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I took the compressor out of the car last night. With no compressor the de frost still blows. Will it still de frost the front windows? I do not want to put the compressor back on. Also can I leave the condensor off ?
  2. Jamie Miles
    It will still defrost fine if you set it to heat.
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Yes.....You can leave all of the A/C parts off
  4. blugene
    Anybody who knows how a defroster actually works will tell you that it wont be as effecent, if it defrosts at all. The evaporator is called that for a reason. But who needs it anyway?...
  5. Jamie Miles
    What does the A/C have to do with the defrost? My car dosen't have A/C and the defrost works just fine...
  6. igo1090
    igo1090 Member
    catonsville, md
    it defrosts just fine without a/c. i've gone thru 2 winters so far with no problem. the defrosters worked well in cars long before a/c became a common accesory.
  7. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Okay so I can take the condensor off too, Right? I'm trying to remove some of the extra weight now. Or just stuff I don't need.
  8. Jamie Miles
    If you're getting rid of the A/C permanently, you can remove everything that has to do with it. You could even go as far as swapping the heater core/blower motor box out under the dash and getting rid of all those vaccume lines.
  9. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    __________________
    gene/blu
    royalgates.net
    Have a Gate Day!
    What the heck are you talking about?
  10. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    That's cool...I just want the de frost to work just in case I get caught in the rain.
  11. Thack
    Thack vision advicator
    Moreno Valley Ca
    New car use the a/c parts to dry the air thus making the defroster work much better. Mavericks do not use the a/c for this but, you can make your old system run the a/c in the defrost mode. All you have to do is file a detent that will let the a/c kick on. Or you can make a remote switch for the a/c and turn it on in any mode
  12. RegL404
    RegL404 Member
    My '75 runs the compressor in defrost mode. My '72 doesen't. If I don't need or want the compressor on when I'm in my '75, I just put the selecter lever in the off position to direct the air to the windshield. When it is rainy and humid, the compressor on removes the fog much faster.
  13. Jamie Miles
    Take your heavy, likely non working 30 year old A/C junk off and your defroster will still clear you window just fine. I promise. Period. :rolleyes: :biglaugh:
  14. Thack
    Moreno Valley Ca
    Now I will have to tear a newer maverick apart (74-77) I thought they started using the a/c in the defrost around 78-79.
  15. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I'm with you Jamie. That thing is heavy. I don't know for sure if it will work but the compressor is staying off. Air still come out the de frost vents when I turn it on but it is warm air. I'm thinking that will give me heat in the winter also. I don't need a/c.
