De-tune
Discussion in 'Technical' started by cam1000, Jul 6, 2006.
  1. cam1000
    cam1000 Member
    Eastern North Carolina
    how and how much can a engine be safely detuned?
    Scenario: a well build 427 engine in a well built chassis car. not so well of a driver. how can we go about detuning the engine without replacing any parts or causing any major damage to slow the car down as much as possible until the driver is up to par.?
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Retarding the timing is one way. Installing a throttle-stop is another.
    I'm sure there are more ways.
    Exactly what magnitudes are you talking about (example: you want to go from a potential 9 second car to a 12 second car?)?
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    smaller carb
  4. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Throttle stop or some kind of a restrictor plate under the carburetor......
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Disconnect the rear throttle plates on the carb.
    Go down one step on spark plug heat range.
    Rev limiter.
    Run a higher gear ratio.
    Restrict the exhaust flow.
    Adjust the throttle blades from opening all the way.
    Use smaller squirters in the carb. *carb suggestions are assuming Holley...
    Use a less aggressive pump cam on the carb.
    Jet up 2 sizes.
    Be careful not to do any mods that lean the engine out and you can slow it down without any ill effects.
    Dave
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Changing Gears ?????
  7. don graham
    run on 2 barrels instead of 4. shift earlier. put a block under the gas pedal, that was an old throttle stop trick, make sure you run an air filter that will slow you a little.:)
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Changing rear gears
    With a 427, changing to higher rear gears may make it more difficult to handle if the 'student' happened to break the tires.
    Think about it. Let's say you have a redline of 7,000-easy with a 427.
    'Student' slips the clutch or just nails it, car is moving at about 10 mph.
    At redline with a 4.11 rear, wheelspeed will be lower than with a 3.00 rear.
    What would you rather try and keep between the lines, a car moving 10 mph while the wheels are travelling at 40 mph or 70 mph?
    In general lower gear ratios can eliminate wheelspin in high horsepower engines for this reason.
    I would look at a MSD/Mallory type ignition box with a rev limiter. Perhaps one is made that can restrict RPM's to 3K or so.
    Are you referring to on a track or driver? Driver I assume. If ignition box won't work, I would retard the timing, depends on the ignition setup. Change/restrict the carb. Wish I had this problem!:rofl2:
  9. igo1090
    igo1090 Member
    catonsville, md
    take some timing out, reduce shift rpm, lower chip in rev limiter.
  10. maverickdvm
    maverickdvm Member
    Michigan
    Get a second Maverick with a 351C in it to learn on while you are finishing the fast car.
  11. cam1000
    cam1000 Member
    thanks for all of the imput guys. as far as the timing goes, can it be retarted too much?
  12. Tylar Miles
    Tylar Miles Try try try let it ride..
    Lawrenceville, ga
    1993 Nissan Sentra
    Detune engine, add ballast, gearing, etc
  13. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Yep. I wouldn't mess with the timing too much. They only thing you're going to do there is get everything all carboned up, and burn an exhaust valve or two while you chase a flame out into the manifold. It'll burn tons of gas and smoke like a freight train.
    The throttle stop is the best way to "de-tune" the engine without taking it apart. If you really really wanted to detune it, it'll need a 2 barrell carb and a peanut cam and cast iron garbage truck intake. That'll make it so anemic you'll be praying it can get out of it's own way.
  14. sierra grabber
    northern nevada
  15. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Msd Al
    I just checked the book. With an MSD spark box featuring the Adjustable Limiter-chips can be bought that restrict RPM's to 3000.
    I'd go that route.
    Seth
