Definition of Acceleration
Discussion in 'Drag Racing' started by Hawkco, Aug 7, 2006.
  1. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I got this off the Galaxie Club e-mail loop....
    Definition of Acceleration.
    * One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of NASCARS at the Daytona 500.
    * Under full throttle, a dragster engine consumes
    1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
    * A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
    * With 3,000 CFM of air being rammed in by the supercharger on
    overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
    * At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in
    chemical reactions are determined) 1.7:1 air/fuel mixture for nitro methane, the flame front temperature measures 7,050 deg F.
    * Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
    * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
    * Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 degrees F. The engine can only be shut down by cutting the fuel flow.
    * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
    * In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 m ph (well before half-track), the launch acceleration approaches 8G's.
    * Dragsters reach over 300 miles per hour before you have completed reading this sentence.
    * Top Fuel engines turn approximately 540 revolutions from light to light!
    * Including the burnout, the engine must only survive 900 revolutions under load.
    * The redline is actually quite high at 9,500 rpm.
    * Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second.
    * The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
    Putting all of this into perspective:
    You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip the second you pass him. You have the advantage of a flying head start. You run the 'Vette hard up through the
    gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
    The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
    Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
    ... and that my friend, is ACCELERATION!
  2. 71gold
    that is good stuff...i think Earl posted this a while back...Earls friend frank...:bouncy:
  3. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    He did...February 2004...2 1/2 years ago. I can't remember yesterday before lunch, much less back that far.:(
  4. Mavaholic
    Still worth reading!!! Amazing stuff.
  5. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I have seen this posted every where. I still read it twice:yup: :bananaman
  6. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    goose bumps and ive never drag raced
