Detent rod to cable
Discussion in 'Transmissions' started by facelessnumber, Dec 5, 2008.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Is it possible to get rid of the C4 detent rod and go to a cable using junkyard parts? Any type of vehicle I should be looking for that would've had a cable instead of a rod?
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Might be able to use a Lokar kickdown cable kit. Another idea might be the throttle pressure cable from an AOD.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I seem to remember a thread about how to convert to a Granada cable.:huh:
    I swear someone has done it...
  4. PaulS
    You have to reconfigure the linkage lever on the C4 to pull instead of push. (take the nut off and rotate it 180 degrees) Then connect a cable from the throttle lever (the bottom side of the throttle lever) to the down-shift lever. Adjust it so at WOT the lever on the transmission moves as far as it can.
    You have just converted to a cable.
  5. ratio411
    ratio411 Member
    Pensacola
    He says "detent cable", which to me is the shifter cable...
    So which is it?
    Are you wanting to convert to a shifter cable, or convert the kickdown rod to cable?
    I think we are all on 'different pages' here!
    Clarify...
  6. mean_maverick
    i think he's talking about the kick-down linkage...
  7. ratio411
    ratio411 Member
    Pensacola
    Okay... then looks like I was the only one on the wrong page! :)
    I was refering to the shifter cable.
  8. facelessnumber
    Memphis, TN
    '71 Grabber
    Yes, I meant the kickdown. Is "detent" not a correct term for this?
  9. DVCRobin
    DVCRobin Member
    Nashville, TN
    1976 Maverick
    Do you know what car (part number ) would be a good donor for this procedure?
  10. facelessnumber
    Memphis, TN
    '71 Grabber
    Actually I did end up using the Lokar cable kit, part # KD20C4HT.
