Did My Whiteface Gauges
Discussion in 'General Maverick/Comet' started by Acornridgeman, Nov 1, 2005.
  1. Acornridgeman
    Wisconsin
    I rehab'd the gauge cluster this morning using the whiteface gauge kit off ebay from Whiteface Gauge Guy (the one that is NOT precut :( ). All went together well and it turned out nice. Picture was tough to take with all the glare, but it will give you an idea how it came out.
    Between the guys instruction sheet and Ray's excellent tech article here on the board, it is quite an easy mod. The absolute hardest part is cutting out all the little windows with a exacto knife. Patients and a steady hand are required. (y)
    Enjoy
    Eric J
  2. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    I have a question, do you know if they make the white face kit for a later year Maverick speedometer that only goes to 100 mph, rather than the 120 mph in the early years?
  3. Acornridgeman
    Wisconsin
    I've never seen a 100 overlay. You could look up and email the ebay seller "whitegaugeguy" to ask. If I had a 100 speedo, I'd switch to the 120 and just put in 120 speedo gear if needed.
  4. A_Bartle
    Michigan's Thumb
    What all would have to be changed to convert to a 120 MPH speedometer?
  5. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Looks great! You'll see a big differance at night time.
  6. Ford_Motorheads
    Ford_Motorheads Ford Addict
    Phoenix, AZ
    1961 Falcon, 1967 Ranchero, 1969 Gran Torino GT, 1974 Ranchero GT 1976 Mustang Stallion, 1977 Mustang coupe, 1978 Mach 1, and 2 1978 Cobras
    Looks nice Eric. (y)
  7. Acornridgeman
    Wisconsin
    If you want to keep your hardware and just change the face of the 100mph speedometer. Ford has a colored gear on the end of the transmission side of the speedometer cable. You can buy different gears to change the speedo needle readings when you change rear end gears, go to a taller or shorter tire, ect... It takes about 5 minutes to change that gear. 1 bolt and 1 clip to get it out. That might be what you need to do. You can get a 120mph speedo from a boneyard and the speedo itself will be correct already without having to change gears. I do believe that it will swap without changes to the gear. I'm sure somebody has done this swap and will let you know for sure.
  8. 71gold
    looks great (y)
    i think the speedo head is all you will have to change :hmmm: ...frank...:bouncy:
  9. sierra grabber
    sierra grabber Certifiable
    northern nevada
    what color lighting you gonna use? i think you can change the green one with a filter lens:huh:.
  10. Mavaholic
    Just use a 120 speedo from another car. Will work fine. Love those white faces. sure looks way better than black faced ones. I really want to do my Sprint but then I'd have to redo the tach and other gauges.
  11. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    looks great, sure brightens up the dash
  12. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    My overlays have been sitting on my desk for about a year now. No patience to do the mod. Yours looks good and has inspired me.
  13. MikeG747
    MikeG747 Member
    Arkansas
    Eric it looks like a factory job. Great work!
    Mike:)
  14. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    looks great. i really like mine
  15. Acornridgeman
    Wisconsin
    Thanks all!
    I'm gonna leave it the factory green, as it will match the Ford Rally Clock I have in the console, radio and the heater controls as well. I did buy the #168 5w lamps for it. Rated 3cp vs the stock 2cp.
