Dim inst cluster
Discussion in 'Technical' started by RudyD, Jan 13, 2003.
  1. RudyD
    RudyD Pretend Mechanic.
    Ft. Collins, Colorado
    1970 Maverick.
    Hey all, my inst cluster is pretty dim at night, I bought some white face guages and they helped some but I still wish it was brighter. What can I do to make it brighter? I have whatever the stock bulbs are in there and I was thinking of putting some LED's back there.
  2. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    My 72 is the same way, good question!
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    mine too... it is only bright when i get off idle...the alternator is putting out more. i imagine if i used a ballsier alt, it would be better. my 70 isn't so bad tho.
  4. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    Solution
    Even with clear glass and all the lights working properly, they aren't very bright!
    One easy solution is a flashlight and a GPS sensor to check your speed. lol
  5. Old Guy
    Old Guy Member
    Dim Lights
    Somewhere in the archives is a post on another bulb replacement that will cure the problem. Should have written the number down myself. Been awhile since it was posted though.
  6. Mavrick newb
    Mavrick newb 20 Year old Mavrick fan
    Central Point, OR
    1973 Mav 351w 76 Mav 302
    I am changing all my bulbs out for LEDs. Blue and white ones for that light blue light effect :D and adding a dimmer switch to controll the brightness.
  7. Mavaholic
    where do you get these LED's?
  8. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    Hey Doug, my dad used to have a candle stuck to his dash he would light for a defroster so I guess the flashlight ideal would work!
  9. DAB
    Austin, TX
    Candles
    The candle could used for a cigarette lighter, too!
  10. bmcdaniel
    If the bulbs are used for any period of time they get dark deposits inside. I cleaned all of the socket contacts and the printed circuit connection to the cluster, put new bulbs in, and painted the inside of the cluster flat white. Made a noticable difference. What made the biggest difference though was the installation of a modern 80 amp alternator.
  11. CometPrincess
    CometPrincess Member
    Port Charlotte, Florida
    1976 Comet 4dr, 1972 Comet 4dr, 1977 Maverick 2dr
    I use an LED flash light, does that count? It would be nice to fix that though and make it brighter.
  12. DAB
    Austin, TX
    Lights
    My lights are nice and bright in my '77 Maverick---when they are working. (About 80% of the time). I guess the contacts on that goofy circuit board vibrate?
    To think we sent a man to the moon with this technology!!!
    I'm not putting down the design, a flashlight works quite well. lol
  13. EenieMav
    EenieMav Member
    Clifton NJ
    1973 Maverick
    This was a question I was going to ask.
    Mine can be on the dim side as well... although when I have the car at idle I get super nova lights. I've recently replaced the original altenator with a 70 amp (go figure that I replace the altenator and a week later that went and had to be repaired!!).
    I had a problem with the dash lights coming on when I put my foot on the brake pedal and the car was off (lights off too), which was the first clue that something was not quite right. Ever since then and the altenator and battery replacement I've noticed that when the car is idle I get the super nova dash, then as I drive they tend to dim, almost to the point of not being able to see. Its most noticable on the side where the fuel gauge is, not so much on the speedometer side although it gets a bit dimmer on that side as well.
    Should I see if a bulb replacement will help? Or is this something to tear the dash apart to do? How do you replace the bulbs?
  14. bmcdaniel
    Sounds like someone has been performing some wiring “upgrades” to your car. The only thing I
    can think of that is common between the dash lights and brake lights is that power for both
    passes through the headlight switch. Are your headlights, tail lights, or markers affected? My
    car has Shelby tail lights and when I apply the brakes those six bulbs alone draw almost 10
    amps. They used to cause the head light switch’s built in circuit breakers to do strange things
    because the contacts got pitted. I ended up jumpering the breakers, adding heavier gauge wiring
    and external circuit breakers. I also had intermittant electrical problems that I eventually tracked
    down to the fuse block interface at the firewall. The fuse block is made up of two pieces, one in
    the engine compartment, the other under the dash. they plug together through the firewall.
    Those contacts on mine were very corroded. Had to take them apart and clean them. That was
    about 10 years ago and I haven’t had any problems since. The dash cluster is easy to take out.
    Just remove the two screws at the top of the gauge openings, reach up behind the dash and
    squeeze the plastic end of the speedo cable and pull it out, tilt the cluster down from the top, lift
    the tabs out from the bottom of the opening. You may have to remove the steering wheel
    depending on what type you have. The bulbs just twist into the rear of the cluster.
  15. EenieMav
    EenieMav Member
    Clifton NJ
    1973 Maverick
    ty... i'll check it out. :D
    I had a blown-out bulb in the drivers side rear marker and I've replaced it, but noticed that it didn't work right away. I'm thinking that maybe there is a loose or semi-broken wire, which worries me a bit, a little bit of messing with the wire made it work right.
    The headlights seem to be affected as well. They will go semi-super nova then calm down, but not to the point where I can't see where I'm going.
    I drive this car daily to and from work and I come home when its dark so I notice the lights brightening and dimming pretty much all the time.
