Disappointed, any ideas
Discussion in 'Technical' started by Scotty P, Dec 14, 2003.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    New rear, shocks, PST bushings and four leafs from ESPO. Was told by ESPO the the new springs would NOT raise the rear more than 1/4" Well..... After getting the P275-60-15's to fit in the wheel wells I am very upset that the wheel wells are now 2" over the tires!!! Ideas? I know I can have them re-arched(a lot of work to remove them again) I have heard of lowering blocks, are they safe? For the strip? Will the springs "settle"? Scotty P:(
  2. Mavaholic
    Been there. As a matter of fact, I'm still there. Lowering blocks are your only answer short of rearching. I put a 1" set on mine and still needs to come down at least another 1". I havent had them rearched for the same reason. I dont feel like taking the car apart. The 1 " didnt have any adverse effect when I ran mine on the strip but I wouldn't feel comfortable with another 1" block in there. I'm sure it would work ok but I wont try it. One day I'll take it apart and have them rearched. Mine have been on for about 1 1/2 yrs now and they havent settled yet. Then again, I've only driven mine a little over 1000 miles.
  3. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    I got the same exact springs in my car and they did settle a bit. Here is what they look like about five months later of everyday driving. The car has 235 60 14s in back.
    -Todd:)
  4. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    nice picture todd
  5. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Thank you Steve.
    Russ put that picture together for me. It was a little sidetrip before the sunday show at pittsburg. I still can't believe he let me drive his mav!!!
    -Todd:)
  6. Scotty P
    Scotty P Member
    santa rosa, ca
    removing leaf
    Won't that soften the spring? I went to 4leaf for the stiffness. I emailed ESPO, I am a bit ticked that they told me no raise in heigth. Mine is not a daily driver so it could take a long time to "settle" Errrrrr Scotty
  7. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    Don't know if it's what you want to do or not but......when I set the rear of my car up with the ladderbars and coilovers I picked up a set of lowering blocks and u bolts from Auto Zone for just over $20 (2") I used them to achieve the ride height I wanted then welded my ladderbars in place then removed the leafs then welded in my coilovers......I would think if you ran somthing like the caltracs that you should'nt have any problems.......another plus was that they came with a size larger u bolt set......you just have to drill the holes in your lower pads....
  8. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    yea go with the leaf removal.....being a 4wd buff too i can tell you that rearched springs weaken in about a year in a truck.. the heating of the metal chages its properties and losses some of the "spring" affect, they will never be the same....you could also make another pair of shakles shorter and as the spring settles over time you could always put the right ones back in it
  9. RudyD
    RudyD Pretend Mechanic.
    Ft. Collins, Colorado
    1970 Maverick.
    Mine settled over two years to just about even with the front. Not a daily driver but still street driven often.
  10. Lightning
    Lightning Member
    Saskatchewan ,Canada
    1971 comet GT
    I've never had trouble with the 2 inch blocks I have in my car . I have 1/2 U bolts holding everything together and the blocs where made from 3/16 material .
  11. jeremy
    jeremy I build t5's
    Corona, Ca
    nice pic todd. I love that stance. Imo, though you should get bigger wheels and smaller profile tires
  12. Scotty P
    Scotty P Member
    santa rosa, ca
    Thanks
    I think I will try blocks, at least for now. I appreciate all the replies...Nice to know we are not alone out here..
    before shot: The heigth I want...
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    Opps
    forgot the photo: here is the heigth I want:
  14. n2omaverick
    n2omaverick Member
    Delaware
    ride height
    nice stance
  15. paul cooper
    paul cooper Member
    chatt. tenn.
    72 ford mav.73 mav. grabber
    NICE RIDE
    Hey N2O MAVERICK that is a sweet ride.Got more pics like the back and the inside?:cool:
