Disc. Brake Conv.
Discussion in 'Technical' started by losi 55, Jan 25, 2014.
  1. losi 55
    losi 55 Member
    Illinios
    72 Maverick
    Been thinking about converting from drums to disc. on the front of my 72 Grabber. Who has the best bang for the buck Kit?
    Thanks
    Butch Wachtor
  2. John Holden
    John Holden Member
    NJ
    Probably stock maverick discs.
  3. rthomas771
    X2 on stock parts
  4. Krazy Comet
    Unless you find a smoking deal on a kit someone didn't use, stock will be far cheaper as well... There are kits that allow the use of the drum spindles, that would save some of the mechanical work but you'd need to do some plumbing...
    I installed '69 Torino brakes on mine(also same as Mustang) but I already had the spindles, still I had to change fittings for brake hoses and master cylinder...
  5. John Holden
    John Holden Member
    NJ
    I like stock parts... But after I posted that I remembered Speedway has (IIRC) some inexpensive brackets that bolt to the drum brake spindles that enable you to use some popular GM brake parts.
  6. Craig Selvey
