disc brake conversion
Discussion in 'Technical' started by Blown74, Dec 24, 2008.
  1. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    First ..Merry Christmas to all ! I purchased a Versailles rear and will also get the discbrakeswap.com kit for the front. Will I need to change porportioning valve? If so what would be the proper one ? This will be a non-power set up. Many thanks!
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Discbrakeswap.com will sell you the correct one.
  3. nybulitt
    nybulitt Member
    Long Island, NY
    72 Maverick
    Go with parts that are easy to find i am running 72 mustang spindles, rotors, calipers, and proportioning valve and i have a 75 maverick master cylinder. Everything works great and parts are cheap so check them out.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I have granada stuff on the front and versailles on the rear and i use a markVII lincoln proportioning valve.
  5. dweesel
    dweesel Member
    Lindsay Ont. Canada
    Is the front disc conversion kit a direct match to the Versaillies bolt pattern? I was looking around for the same set up for my '70 but not sure about stud pattern dimensions.
  6. rthomas771
    According to This Site "The Lincoln Versailles (Lincoln's Granada) uses the same parts as the Granada EXCEPT for the spindle. A Versailles spindle has larger holes for the ball joints, and won't work in this swap!!"
  7. Bryant
    all ford, lincon, mercury cars use the same bolt patern except for a few full size lincons.
  8. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    The May 2003 issue of Hotrod or Car Craft has a full story on the swap to a Falcon. Same parts etc. Lots of pictures and directions. Did my Ranchero from that story
  9. DragPack428
    DragPack428 Member
    Easton, Pa.
    I have the Lincoln Versailles discs on the front of my Comet. You need an adaptor sleeve to fit the tie rod ends. If someone needs to know where to purchase, drop me a PM. I'd have to search but sure I could find the source. They were about $30 each so be sure to thake that into account when comparing prices to Granada spindles which fit without the sleeves.
  10. rthomas771
  11. DragPack428
    DragPack428 Member
    Easton, Pa.
    Yes that is the place. Had to buy a set to fit the Versailles to the Comet then another set to fit the Comet's to my wife's 66 Mustang convertible.
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  13. rthomas771
    The Mustang and Mavericks shared the same rotors but the spindles were different
  14. Jamie Miles
    What is different about them?
  15. rthomas771
    The parts catalog shows different part numbers each year for the Mustang (68-73)except 71-72 share the same number. 75-77 Maverick and Granada share the same number, 74 shows a different number than the rest of the Mavericks. I guess it's possible since the 75 Mustang was smaller than the earlier Mustangs Ford could had used the same part with a different number. I know Ford wouldn't go through this trouble in the Engine or Trim Department in the late 60's. They still used '57 part numbers on '79 Trucks.
