Disc Brake Conversion
Discussion in 'General Maverick/Comet' started by qkrthnu, Mar 10, 2012.
  1. qkrthnu
    qkrthnu Member
    Michigan
    1973 Comet GT
    Scored a set of Granada spindles loaded with calipers for 75 dollars gonna install in morning what do I run for hoses these are weather checked bad and do I need a new pro portioning valve
  2. 71gold
    some say yes...I say no...:huh:
  3. captainmack
    captainmack Quad Door
    You need to get a new master cylinder...the drum/drum mc has risidual pressure valves that are too much for the discs.. the metering block is not the only issue. I observed that the drum drum block has smaller passageways going to the back...it really isn't right formany reasons...get a new disc drum block and plumb it in or a wilwood with a proportioning screw knob to really get it tuned perfectly.
  4. Dave B
    Get some hoses for a 74 Maverick, with disc brakes. You may need to re posion the steel brake lines. There are some post about this from over the years.
  5. captainmack
    copy and past this into a google search bar...
    site:mmb.maverick.to proportioning valve
    click on the first result..
    from that I posted:
    I got the Granada discs installed and found a Fairlane 8" rear axle with 10" drums in new condition...my old rear drums were 9".
    I found;
    The drum/drum M/C has two 10lb. residual valves accesable just behind the flare fittings where you take the metal lines off.
    The disc/drum Raybestos MC36440 which is a manual disc drum master cylinder, for a '74 Maverick has a 10lb. residual valve for the back DRUM brakes in the front res. (which is for the back) and there is NO residual valve for the front discs (back end of the M/C). The residual valve for the discsa would be 2lbs, and are routinely sold, but only on cars where the master cylinder in at or lower than the disc calipers. So I am not going to ad a residual valve for the front discs.
    I am going to replace my drum/drum metering block(?) with either a new ford style combination distribution/proportioning/metering valve http://cgi.ebay.com/ebaymotors/1960-...item2eb5ce9554 or a combination adjustable proportioning/distribution valve; http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
    I would love to know if they do the same thing or if the ford valve does something extra to make my road car safer.
    I found this post here that stopped me in my tracks from buying the adjustable one;
    "The Granada came with a combination valve...not a proportioning valve. The combination valve is a fluid distribution valve, proportioning valve, metering valve and pressure differential sensing valve. The combination valve works better than an adjustable proportioning valve in wet weather."
    this trick of
    followed by whatever topic you want to find is better than this sites search function.
    -M
  6. 71gold
    all the above may be great...but me and others have used the...drum-drum MC with no problems...
    I also ran it with my...4-wheel disc setup...
    ...:drive:...
  7. 71gold
    you did a neet job on yours...(y)
    mine has none of that stuff...
    the lines run straight from...MC to the 4 calipers...no problems...:thumbs2:
