Disc Brake Master Cylinder
Discussion in 'General Maverick/Comet' started by ford71, Apr 1, 2015.
  1. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    After 3 hours of reading last night I have seen people with various opinions. Trying to clarify up so I can make the right decision the first time. I currently Have fron disc brakes with a 1975 Disc/drum M/C. I am converting the back brakes to disc. Can I leave the M/C that i have in there?
  2. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    I believe that there is a 10 psi residual valve in the master cylinder and that will cause the rear brakes to slightly drag. so you can use a punch to break the valve or get a master without a built in valve. If you have power brakes you can use a versaille master. Otherwise I read on a manual system you want to use a master that is 7/8" or smaller.
  3. 71gold
    I ran the disc/drum MC on my 4 wheel disc, no problems...:thumbs2:
  4. mav1970
    If you can adapt a Tilton or Wilwood racing master cylinder with any residual built in, just use the 2 pound residual valves sold by Summit - it's what I used on my stock cars with 4 wheel disc brakes
  5. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    Thank you for the response. Since I already have the disc/drum m/c in the car I will try that. I took it apart tonigh and did not find a residual valve in it so since it worked form 71Gold I will see.
  6. 71gold
    what size tires do you have front/back?
  7. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    I have 205 70 14 front and 235 70 15 back
  8. 71gold
    the reason I asked...the brake system I have now has no prop. valve. the lines run from the MC to the front brake calipers and from the MC to the rear calipers. the larger rear tires I run are the bias for the system. this is the same system that Coupe Performance (Scott) runs on their street/drag cars. I got one of the MC they use and the instructions how to plumb it.
    here is the 347 they built for my Mav.
    me and some of the Ga. Guys getting my Mav dyno tunes....:thumbs2:
  9. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    Wow that looks awesome! Bet it sounds even better. After my daughter gets here first year under her belt 347 here I come!!
  10. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    Where can I get those instructions to eliminate the porpotioning valve? What diameter tires are you running?
  11. 71gold
    I will check on the size...
    PM sent...:thumbs2:
  12. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I put disc brakes on the rear, 96 Crown Victoria don't seem to have any problems with it I got a washer from a member on here to take up space in the back back plate
