Disc Brake Problems
Discussion in 'New Members Forum' started by mdpatter, Sep 7, 2010.
  1. mdpatter
    mdpatter New Member
    Maine
    1971 Grabber
    I have a 71 Grabber with a 302 and a 5 speed which had disc brakes on it when I bought it. The drivers side sticks and the brakes drag. I have fixed it a dozen times but the problem returns. They look like they don't belong on the car. The piston in the caliper only covers half of the pad. I have no idea who put them on or from which car. My question is will the standard disc brakes which came on the 74 Maverick bolt up to the 71?
    Thanks for any help you can give in solving my brake problems.
  2. Mavman72
    Yes they will...You will need the spindles from the donor mav as well.
    Oh!!! Welcome to the center of the Maverick/Comet universe!!!
  3. gran maverick
    gran maverick Member
    martin ga
    72 maverick
    :Welcome: from Martin GA
  4. rayzorsharp
    Welcome aboard! Nice car too. Disc brakes from a Granada or Monarch are the same also just in case you know where one of those are.
  5. mav1970
    :Welcome:from Northeast Pennsylvania
    Very nice :thumbs2:
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
    Nice lookin ride!!!!! :thumbs2:
  7. CaptainComet
    Nice looking Mav :thumbs2:
    Just wanted to add that when swapping from drum to disc, outer tie rod ends that match the spindle are needed. Since yours are already modded somehow, you may already have the right ones. It would be something to look at if you decide to change things.
  8. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    What have you done to fix the problem? If it is just replacing pads or even the caliper then I would look at the brake hose. Sometimes the inside of the hose will come apart and not let the fluid return to the master cyl. Happens all the time on trucks and mini vans.
  9. mdpatter
    mdpatter New Member
    Maine
    1971 Grabber
    Thanks to all for the quick responses. I check your suggestions.
    Mike
  10. david_h_30170
    david_h_30170 Member
    Roopville,Ga
    1973 2 door v8
    :Welcome: Nice looking car
  11. mightymav72
    mightymav72 Member
    Sevierville,Tn
    1972 Ford Maverick with a 351 Windsor
    Nice car yes, but love your garage.Welcome.:thumbs2:
  12. Mercurycruizers
    Venetia, PA
    :Welcome:to the board. Nice looking car. Yes, I agree with looking at the brake hose....
