I'm wondering what the best way to go ? Should I buy a used Granada proportioning valve with the reduction already set and mount that or use a after valve and install it in the rear brake line. Just wondering what most of you guys have done Thanks Rick New wheels coming Weds
The Granada came with a combination valve...not a proportioning valve. The combination valve is a fluid distribution valve, proportioning valve, metering valve and pressure differential sensing valve. The combination valve works better than an adjustable proportioning valve in wet weather.
