Disc brakes
Discussion in 'General Maverick/Comet' started by Bossed, Nov 25, 2009.
  1. Bossed
    Bossed Member
    Fort Barnwell, NC
    70 Grabber, 70 Maverick
    Hey fellas, I've found 76 Comet for parts, I don't know the condition of the car yet, but I saw somewhere that starting in 1976, disc brakes were standard,is that correct? If it is, are there any roadblocks to swapping them to my 70? It was originally a six cylinder, I'm wondering if they're power disc.:)
    Bossed
  2. Bossed
    Bossed Member
    Fort Barnwell, NC
  3. Joe Dirt
    should work no problems just use the related parts like lines and master cylinder and prop valve to do it right
  4. Bossed
    Bossed Member
    Fort Barnwell, NC
    Thanks, I love your car!:thumbs2:
  5. JHodges
    JHodges thumper
    Dora Alabama
    you will also have to use the rubber line that goes to the caliper from the 76. It is an easy swap to do. If it has a booster it is power disc
  6. 69.5mav
    69.5mav Member
    Oregon
    All the parts on my 70 were from a 76. I used all the steel lines from the master cylinder to the prop valve on down to the brake hoses from the 76. My parts car had power also but went with manual disc. You will need the 76 outer tie rod ends also I believe.
  7. Bossed
    Bossed Member
    Fort Barnwell, NC
    Thanks for that info, I really appreciate it:tiphat:
