Disc vs Drum - non-power MC difference?
Discussion in 'General Maverick/Comet' started by Powerband, Mar 14, 2018.
  1. Powerband
    Powerband Member
    NY's \H/
    NON POWER DISC BRAKES - NON POWER DRUM master cylinders:
    Are there actual different master Cylinders for '76 Maverick non - power drum vs non-power disc?. I haven't been able to find any listing for MC - NON POWER DISC different from NON POWER DRUM MC's.
    thanks
    ... IF they are the same, how does it work without actual proportioning valve . The 'pressure differential valve/switch just lights up dash warning and doesn't alter MC pressures.
    haev fun
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    In '76, all Mavericks had disc brakes up front. The power m/c is different from the non-power. The all used a proportioning valve.
  3. Craig Selvey
    Yep....no drum brakes in 1976.
  4. CaptainComet
    I have Granada discs up front and factory drums out back. After swapping a late non-power MC, the rears were locking up a bit early, and I added a Wilwood adjustable prop valve.
    As a side note, you will need the shorter rod from your original MC. The disc MC rod is too long. Do a search, there is a good discussion here on how to swap them.
    Crazy Larry likes this.
