Disconnecting Brake Actuator Rod
Discussion in 'Technical' started by Drew Hierwarter, May 8, 2020.
  1. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    Here we go again. Has anyone disconnected and then reinstalled the rod between the master cylinder or brake booster and the brake pedal? How did you get up under there to get at the connection? Did you have to remove the front seat to get enough room to gain access? Any tricks, tips, or other ideas?
    As it is right now I can get two fingers up in there but now way I can what I'm doing.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The fun of working under the dash! Your best bet is to hire a contortionist from the circus.:biglaugh: Although it isn't the easiest, removing the seat really does make a big difference in gaining access. Other than that, it sucks and fights you all the way. Good luck and have fun!:thumbs2:
    Russell, Drew Hierwarter and mojo like this.
  3. mojo
    If you have bucket seats, take the seat out, esp., if your over 40 years old! Whatever seats you have, much easier w/ seat out..
    Drew Hierwarter likes this.
  4. Drew Hierwarter
    Kingsport, TN
    1976 Comet
    I have a bench seat and I'm waaay over 40 and I can't find any circus contortionists so . . . . :)
  5. Craig Selvey
    There is a "pin" you have to pull out. I find it easiest to open the driver's door, then sit outside the car on the ground and this will give you a bird's eye view. Might help to have the car up on jack stands when you do this.
    mojo likes this.
  6. Drew Hierwarter
    Kingsport, TN
    1976 Comet
    Got the front seat out and got up under the dash and was able to disconnect the brake rod from the pedal. Time remove the brake booster. Uh, where are the bolts? I don't see more than two and they don't look like they're in the right place. The shop manual I have simply says; " . . . remove the fasteners. . .". I have now idea how I'd get any sort of wrench up in there anyway.
    I sear, the next car I own that needs a new brake booster, I'm just selling it and buy something else.
    #frustrated
  7. Krazy Comet
    Get a '66-'71 Fairlane/Torino/Cyclone/Ranchero etc. Booster bolts to bracket under hood, doesn't need disturbed. Can remove master cylinder & booster nuts plus one cotter key & pin, ease MC forward, lift out booster. Not necessary to loosen fluid lines.
    Even easy-peasy on big blocks.
  8. Craig Selvey
    There are 4-bolts inside the car that need to be removed.
    There are two located where the green circles are located. The other two are a few inches above each green hole. The brake rod goes thru the blue hole.
  9. Craig Selvey
    The (4) nuts would be located at the brake pedal support bracket. This would be at the top of this picture.
    Russell likes this.
  10. Maverick392
    Maverick392 Member
    Las Vegas
    I just recently did mine. My car has buckets and a door bar for the roll cage which makes removing the seats a pain. I found that I could sit on the ground outside of the car and reach up in there pretty easily. I didn't have a great view, but was able to get it in and out by feel.
    Craig Selvey likes this.
  11. Russell
    Russell Orejano
    New Mexico, 88022
    Maverick
    Had a contortionist mechanic working in the Philippines....called her the Manila Folder.....sorry, couldn't help it...
