Distibuter ID and Help
Discussion in 'Technical' started by downhillbiker, Feb 13, 2012.
  1. downhillbiker
    downhillbiker Member
    Salt Lake City, UT
    1976 Stallion/Grabber
    There was question about what distributer I had in another thread. I think it is a duraspark system, but I don't know who makes the distributer. I am trying to figure out exactly what cap and rotor I need? And does this have points or eletronic, I think electronic, but honestly don't know how to identify properly. Can I buy any performance or stock cap and rotor?
    Duralast box?
    Numbers on the back of distributor, google search has hits on mustang distributor, but doesn't give me info on which cap and rotor to buy.
  2. downhillbiker
    Salt Lake City, UT
    76 Maverick Grabber
    Has MSD coil as well:
  3. Craig Selvey
    No such thing as a 1976 Grabber. I think it is a Stallion.
  4. downhillbiker
    Salt Lake City, UT
    Do you think this one would work? I like the color, and it's cheaper than local parts store. Local store has "performance" models, do they make a difference?
  5. downhillbiker
    Salt Lake City, UT
    I just ordered a Marti Report. I will find out for sure soon enough. If it is a stallion, I think they are pretty valuable. I may just sell the car and buy an older Grabber.
  6. baddad457
    Definately a Duraspark. Do yourself a favor though and upgrade to the large post type distributor cap. This setup was used on the early 80's Duraspark with the same distributor, it just uses an adapter between the cap and distributor body. The whole setup (adapter, cap and rotor) can be bought in a set at the local parts house. Get the set with the brass terminals. Then also get a good quality set of spark plug wires to match. I use the Ford Racing 9mm wire sets, they only cost $40-45 and are good for 3/4 years service.
  7. downhillbiker
    Salt Lake City, UT
    I plan to do the wires and plugs too.
    Can you provide a link to the larger post type distributor cap? I am trying to buy everything from summitracing.com, so if you can find it on there that would be great.
    I found an ACCEL performance cap, not sure if it is the same.
  8. downhillbiker
    Salt Lake City, UT
  9. baddad457
    No need to order it from Summit, when you can get it from the local parts house. Unless you just like to wait for the UPS guy. It's a stock Ford Duraspark distributor. Get a cap & rotor kit for an 85 Mustang HO, plus the matching spark plug wires, don't cheap out on the wires.
  10. downhillbiker
    Salt Lake City, UT
    They didn't know anything about it. Do you have any more info?
  11. baddad457
    Go ask for a cap, rotor and cap adapter for an 85 Mustang GT with the 5.0 HO motor. Get the wires too. If they cannot fill this simple request, go to another parts house that will. It's not rocket surgery. I'm using this same setup on my 77 Comet, same distributor as yours, only mine has a steel cam gear to match the roller cam.
  12. Dave B
    Here's what the post type looks like:
  13. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    NAPA KNOW HOW!!!!! NAPA KNOW HOW!!!!! IF they cant find it just ask if you can look through their book. ITS in there.
  14. downhillbiker
    Salt Lake City, UT
    MSD part no. 8414?
  15. baddad457
    Yes, that will work. As will the same thing as what you'll find at the local parts house.
