Distributor questions
Discussion in 'Technical' started by Dean Deeter, Aug 27, 2013.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    There are two electrical wires coming out of distributor,one goes to the coil. Where does the other go?
    Also the Vaccum advance has two places for Vaccum,can I run one tube over and split it at the advance or do I need to run seperate ones.
    The only other Vaccum I have hooked up is to transmission is that all I need? I thought I took enough before pictures but I did not...
  2. rthomas771
  3. Dean Deeter
    Dean Deeter Member
  4. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    I see a wiring diagram and a nice writeup regarding the vacuum advance. Did you click on the link?
  5. Dean Deeter
    Dean Deeter Member
    Yep see the vaccum setup. And it helps. The wiring diagram does not show 2 electrical wires coming out of distributor.
  6. Dean Deeter
    Dean Deeter Member
    Does anyone have 2 electrical wires coming out of their distributor aswell?
  7. Dave B
    Do you have a pertronixs?
  8. Dean Deeter
    Dean Deeter Member
    Yes I do have a pertronixs
  9. 71gold
    pertronixs directions should tell you where to hook them.
  10. Dean Deeter
    Dean Deeter Member
    Getting a little late will check tomorrow.. Thanks
  11. Dave B
    The black wire goes to the negative coil terminal, and the red wire goes to the positive terminal, plus there should be two wires from the engine harness to the coil. There may be one that is purple with yellow dashes, that's usually the wire the goes to the positive wire on the coils, the other is a ground. But it's always best to use a multimeter to check.
  12. rthomas771
    Red wire to coil + Black wire to coil -
  13. Dave B
    That's what I said..:hmmm:
  14. 71gold
    while he was typing...:bouncy:
  15. Dean Deeter
    Dean Deeter Member
    Thanks for the help ,got it running.
