distributor shaft length?
Discussion in 'Technical' started by xpsnake, Apr 19, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    My block is an '89 roller 302 and I picked the correct for racing gear to use a point dizzy on my setup, however, in looking at the points vs the electronic dizzy, the shaft lengths are very different, several inches. Is there a points dizzy that will fit my late model roller block?
  2. igo1090
    igo1090 Member
    catonsville, md
    i could be wrong, but i thought all 302 distributors were the same as far as dimensions. is one for a 351W? it would have a 5/16 drive slot in the bottom instead of a 1/4 drive slot. by slot, i mean allen wrench opening.
  3. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    the 302 melling part# is is-68 is 7.44 length 351w is-83 8.19 length 302 1/4 hex 351 5/16 hex hope this helps just looked it up at work
  4. inline6
    inline6 Member
    as far as i know all 302's are the same length.sure you don't have a 351 dizzy?
  5. bmcdaniel
    I'm running an old distributor in my roller block. As mentioned, you probably have a 351W dizzy. BTW, with the Edelbrock retrofit roller cam I have you can keep the cast iron gear on your distributor and keep the old 15426378 firing order,too.
  6. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Sounds like 302 vs 351 is only .75 inch difference. It ain't a 6-cylinder dizzy is it? Those are very short ... :) Make sure you only measure the lenght of the tube that goes into the block ... I would imagine some dizzys may stick up higher than others ... :huh:
  7. xpsnake
    xpsnake Bruce
    Parts store must be having some issues with their computer, because it said '71 302 for the one and '88 302 for the other, when I compared them, there was a huge difference.
  8. NAFORD302
    NAFORD302 Member
    SILEX MO
    the 302 used same shaft from 1968-1995 out of the melling book
  9. sierra grabber
    sierra grabber Certifiable
    northern nevada
    probably a big block dizzy
  10. Cleaver
    Cleaver Member
    MD
    Chel
    See picture for correct distributor shaft length.
