do do you guys think this is a good deal
Discussion in 'General Maverick/Comet' started by classic ccg, Oct 11, 2012.
  1. classic ccg
    ringgold GA
    72 maverick
    302 engine completeits a 92 or 93 he told me its out of a truck
    e 303 cam its not in the engine
    its efi
    so he is giveing me the wire harness thr out side one fuel pump
    a alternator
    and a electric fan
    and a fly wheel
    and some more things he finds
    and all he wants is 350$
    what do you guys think
    and i was looking at this one to
    http://chattanooga.craigslist.org/pts/3323570189.html
      File size:
      93.6 KB
      39
  2. Dave B
    Whats the mileage? If it came from a truck...you never know, it could be beat.
  3. classic ccg
    ringgold GA
    72 maverick
    he told me 120k
  4. 71gold
    are you going to keep it EFI?
  5. Krazy Comet
    For the Craigslist engine, any '87 up 351 except for Lightning is going to have the E7 heads, same as '87 up HO 5.0...Yeah I know it's 5.0 but the point is the heads aren't likely a big deal... If the heads were the GT-40 like used on the Lightning then yeah it's desirable feature...
    Have you verified the truck engine has a roller cam? It's possibly a roller block with a flat tappet cam, which would mean it needs lifters, retainers & spider to use the E303... That cam will need to be used with mass air or carb, it won't be very happy on a speed densety system...
  6. classic ccg
    ringgold GA
    72 maverick
    i was goign to keep the efi but i havea intake and carb i can put on there
    till i get all the info and parts for the efi set up
  7. classic ccg
    ringgold GA
    72 maverick
    how do i verifie it ?
    will the e 303 cam fit if its not?
  8. Krazy Comet
    If the engine is together, casting number and date code can be checked E6xxx, F1xxx etc are at least roller ready, thought may not be machined to accept the hold down spider... Otherwise the push rod length can be checked, 6.27" is what roller lifters use, the ones for flat tappet are 6.80" or slightly more than ½" longer...
  9. predfan2001
  10. Joe Dirt
    I do believe pre 94 is flat tappet camshaft for trucks and vans
  11. Krazy Comet
    The 5.0 got a roller cam for the redesigned '92 models, 5.8 got roller for the '94 model year(Lightning excepted, all were flat tappet)...
