Do I need a plate for a floor shifter
Discussion in 'Transmissions' started by Doug, Mar 10, 2016.
  1. Doug
    Doug Member
    washington state
    71 maverick grabber
    I am working on moving a floor shifter in my car . Has a column shifter now . Somewhere I saw a article showing a factory shifter with an adapter plate ? Do also need an adapter plate ? You just can't cut a hole for it on the tunnel ?
  2. 71gold
    the "hump" just makes for a neater install...JMO
  3. 71gold
    the "hump" is to sit the shifter level and to one side of the tunnel so the linkage can work properly.
    thanks...mich mercury...for the pic...:Handshake:
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I would use one for a manual trans. For my auto trans, I did not use the hump. I did however reinforce the shifter mounts underneath in the trans tunnel. I used a 71 - 73 Mustang shifter with a 68 Mustang V8 rod. The rod required slight bending, but nothing major.
    Crazy Larry likes this.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You don't need it. It raises the shifter ever so slightly. There's an outline on top the trans tunnel for where to cut the hole.
