Do I need "break in" oil?
Discussion in 'General Maverick/Comet' started by Racer_X, Jan 3, 2015.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    I have herd two different things A) I need to use break in oil when firing up a rebuilt motor B) Just put zinc additive in the motor oil of your choice (which I have done) after I resolved my fuel delivery issue several months ago my project has been collecting dust because of college and work, I'm revisiting this stage of my build so that I have everything in place so I can finally try to start it again and break in the cam properly once and for all. I have 5w30 Pennzoil and a full bottle of Lucas zinc additive in the motor, I think I may swap to 10w30 once its on the road.
  2. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Yes you need break in oil
    hopefully you used a good cam/lifter assembly lube such as ZPaste or Joe Gibbs Drivin
    Use a break in specific oil like joe gibbs offers
    Do the usual 20 min break in at 2500rpm for cam
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Cant just put zinc additive in with off the shelf oil as that oil forumlation has calcium. Which essentialy strips any metal to metal cushion..
    After breakin either or weight toy mentioned will work well
    But thinnest oil to give you 10 lbs per 1k rpms would be best
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
  5. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Avoid everything ive said if you have a roller cam/lifter setup
  6. 71gold
    what engine do you have and some specs?
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Flat-tappet cams should have a zinc additive or break-in oil. Either will work fine.
  8. mav1970
    Absolutely - I picked up my Cleveland from my engine builder with 7 quarts of Joe Gibbs break in oil in the pan
  9. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    The main thing to succeed in proper breakin is if you have dual valve springs, remove the inner spring while doing the cam breakin
    Then reinstall inners after
    rthomas771 likes this.
  10. rthomas771
    ^^ Good advice about the inner spring
