Do I need this part??
Discussion in 'Technical' started by |MaverickMat|, Sep 18, 2009.
  1. |MaverickMat|
    |MaverickMat| '74 Grabber
    Portland, OR
    1974 Grabber
    So i have 1.6 ratio, Comp cam roller tip rockers sitting on top of recently installed 3/8" screw in studs. I'm using Comp cam poly-lock nuts (the kind that has the allen-headed middle screw that you tighten down). My question is this: there is a black spacer that went between the nut and the rocker arm pivot ball. The spacer no longer fits, as I've upgraded my stud size to 3/8". Do I need this spacer? I kind of feel like it's necessary if you're doing self-locking nuts, but I've tossed those in lieu of the poly locks.
    Any info is appreciated!
    Mat
    (I've included a nifty picture of the spacer in question.)
  2. 71gold
    I would suggest calling...Comp Cams...:Handshake
  3. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I would as well call Comp Cams
  4. Gone'70
    Gone'70 Member
    Copperas Cove, TX
    70 MAverick, totaled 8 years ago!! + Dads '73 MAverick
    A phone call is the best. A guy i new didnt install those rockers correctly and had to buy a new valve train set up, being there was shavings all in the heads!
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I would call Comp Cams, but it sounds like you may need to buy rockers for a 3/8 stud.
