Do mustang rear seat covers fit mavericks?
Discussion in 'Cosmetic' started by 7D2 Grabber, Apr 30, 2009.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    For a 72, thanks
  2. Dave B
    Not without some work.
  3. 7D2 Grabber
    7D2 Grabber Member
    What kind of work is needed?
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    My uncle put a set in his 70. They don't fit well, and he did quite a bit of work to them. He does commercial canvas and boat canvas, so he has commercial sewing machines. It looks okay, but you can still tell it isn't right. The rear seats are substantially more different than you would think. The fronts are the same of course (71-73).
  5. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    Chris M. In PA use Mustang seat covers front and rear on this 70 Grabber clone and they looked pretty good to me. If I ever get that far with mine to install front buckets I would love for mine to look as good as his did.
    Bob
  6. 7D2 Grabber
    7D2 Grabber Member
    What year mustang? Coupe or conv?
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I've got a beautiful (blue) factory cover from my '72, looks like it's never been sat on. Removed to narrow seats for my minitub job. PM me if interested.
    Russ
  8. 7D2 Grabber
    7D2 Grabber Member
    I need it in black and to match my fronts which will most likely be like the Mach 1 seat
  9. bmcdaniel
    bmcdaniel Senile Member
    JC Whitney used to sell custom Maverick rear seat covers. The place that makes them had the old patterns.
  10. ratio411
    ratio411 Member
    Pensacola
    My uncle used 71-73 coupe back seat covers.
    He put them in a 70 Maverick, so I guess that might be the difference according to another post. His seat back was wider than the Stang cover. The bottom is shaped a bit different too.
    Mach rear seat (fastback) covers will NOT work. They are totally different.
  11. 7D2 Grabber
    7D2 Grabber Member
    I just bought a set of maverick high back buckets need recovering but they have the spacers
  12. CaptainComet
    Ratio is right about the folding Mach rear seat not working. The upper cover is split halfway up the back.
    That leaves you with a choice of coupe or convertible covers in Standard or Deluxe patterns.
    I have put a lot of work into prepping for this myself ... the 72-later rear seat bottom is narrower. I bought a set of coupe covers, and in retrospect, I believe that convertible covers would fit better width-wise.
    Now, here is where it gets tricky ... the rear seat bottom cushion is much taller than the Mustang set, and the Mustang has more rise to it over the tunnel area. LDO rear seat bottoms are an inch taller than standard Mav seats as well. Very long soon-to-be tech article cut very short ... the rear seat bottom frame needs to be shortened 3 inches or so in height... you have to re-engineer the springs, and re-arch the tunnel. It was a lot of work and head-scratching, but my buddy that did upholstery for 20+ years looked at a trial fit of the cover and said that I pulled it off. It will be months before I am ready to upholster the seats, so that tech article will have to wait ... sorry.
    The seat backs between Mav and Mustang coupe look like they well might be the same part ... very good fit. I am not sure if convertible Mustang seat backs are narrower, but I don't think they are. Measure to be sure.
  13. 7D2 Grabber
    7D2 Grabber Member
    Is there a difference between the 69 and the 70 mach 1 cover? I have some 73 maverick seats that seem to have decent foam. I'll be recovering without replacing the foam. As for the rears, my rear seat is in very good shape so all i need is the insert to match the front seats. I'll get an interior shop to add the comfortweave inserts to the rears to get matching interior.
