Do you know what type/year of power assisted brake booster we can use?
Discussion in 'General Maverick/Comet' started by mjm0395, Jul 10, 2015.
  1. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    any info will help...
  2. 71gold
    some have used...Geo
  3. Krazy Comet
    Unless you go with the original contraption that Ford used, AFAIK there is no such thing as a booster that'll bolt on without some modification or fabrication..
    With a short enough master cylinder(most orig types are too long), the 7" diameter universal units on ebay will fit between firewall and shock tower, at least that is if bolted directly to firewall(adapter brackets are a no no)... It will require drilling firewall, modifing/fabbing the MC lines and hookup of the pedal rod... If a GM MC is not used, you'll probably have to elongate the MC mounting holes slightly...
    http://www.ebay.com/itm/7-ZINC-POWE...L-A-/300799070248?hash=item4609059028&vxp=mtr
    BTW if you decide to try one of these from ebay, shop around... Seen them for $35 or less...
  4. Paul Masson
    1971 Grabber
    If you are converting a manual-brake Maverick/Comet to power brakes, using the stock Mav/Com booster, you will still need to drill some extra holes and replace the brake pedal bracket, etc... as per Craig's Tech Article:
    http://mmb.maverick.to/resources/converting-to-power-disc-brakes.17/
    Krazy Comet likes this.
  5. Craig Selvey
    And unless you have disc brakes, don't waste your time until you do that swap first.
  6. Krazy Comet
    Maybe, but I had a '67 Falcon Wagon with 289 that had power drums, had reasonably comparable brakes to the '69 Cobra in my sig(both owned at same time)... No doubt would fade on a steep incline long before the discs but I'm on flat land, in a metro area, never found them inadequate...
    WAIT there was one exception, the time I was towing a yard of concrete... But that weighed nearly as much as the Falcon, wasn't going to be anything even vaguely resembling a quick stop, even if it had discs...
    Craig Selvey likes this.
  7. rthomas771
    Nothing wrong with drum brakes if you know not to use drums that have been turned too many times and know how to adjust them periodically. Brake shoes have more contact surface than disc pads.
