Does anyone have a part number for the larger wheel cylinders on a '72 comet?
Discussion in 'Technical' started by Phyphor1, Nov 19, 2020.
  1. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    Specifically, the rear ones.
    I keep winding up with the smaller sized ones, and it's frankly frustrating.
  2. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    From what I find these are .844 diameter: C2OZ2261C, C3OZ2261C, D3DZ2261A
    These are .906 diameter: C2SZ2261A, C3OZ2262A, C6TZ2262A, C7AZ2262A, C7AZ2262C, D1AZ2262A, D2OZ2262A, D2OZ2262B, D3OZ2262C, D3TZ2262B, D5DZ2262A
  3. Doug
    Doug Member
    washington state
    71 maverick grabber
    I found one inch diameter from napa part number up9026
  4. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    These are the ones that should work. These are from Advance Auto Parts and are the Carquest Brand. I ran into the same problem ordering brake cylinders for the Maverick Rear in my 1938 Ford Coupe. I ordered ones for my 71 Comet and they were smaller. Ordered ones for a 1975 maverick and they were larger. The smaller ones are listed at 27/32" bore and the larger below at 7/8" bore.
    Rear Right; Bore: 7/8 In.
    #WCA17508
    Rear Left; Bore: 7/8 In.
    #WCA17507
  5. Krazy Comet
    Ford Master Parts lists 27/32" as only cylinder '71-'73, while '74-'75 used 7/8" and '76-'77 were 15/16".
  6. mojo
    Does large bore size make improvement in braking effiency
  7. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    It changes the brake balance. The master cylinder, front wheel cylinder, and rear wheel cylinder sizes are all juggled to get the best combination of pedal pressure, pedal travel, and front/rear brake balance. A larger wheel cylinder will put more pressure against the shoes at the expense of more pedal travel. Ideally the front brakes should lock up before the rears, but only barely.
    mojo likes this.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Sorry to bring alive an old zombie thread, but Im gonna do it anyway
    I bought a new rearend for the Mav. Was told it was a 73, nope its got to be a 74+ cuz the back center hubs are bigger. Now I need new wheel brake cylendars. I am seeing online, and as also stated above, that it seem 74/75 use one , and the 76 uses another. There is no part number on the existing.
    How can I tell what I have and which I need?
    and does it really matter if i use a 74/75 or a 76, since the master, and front disk, propotioning valve are all new and need adjusted anyway?
