Does anyone know
Discussion in 'Technical' started by 1moregear, Jan 20, 2010.
  1. 1moregear
    1moregear Member
    mississippi
    74 and 76 maverick
    What the U bolts torque at with an 8 inch rear? Thanks.
  2. justin has a 74
    kentucky
    Dont think it really matters but you might want to wait for someone else to reply lol
  3. Mavman72
    I put 65 lbs/ft on mine in the Sprint.Dont go gorilla on em you will bend the axle tubes.
  4. mean_maverick
    german spec....
    good-n-tite
    :D
  5. rthomas771
    U-bolts are 35-50 ft lbs
  6. scooper77515
    Chilton's Maverick/Comet 1970-77 book says 8-15 ft/lbs. At least for the bolts that hold those C-clamps at the u-joint caps. If that is what you are asking.
  7. ShelbyMaverik74
    ShelbyMaverik74 Member
    Enon, OH
    1974 Shelby Mav Clone
    I believe the German spec is actually
    "Geuten tiht"
    Aloha
  8. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    I was told by the shop that shortened one of my driveshafts, to install new lock washers, and tighten the nuts until the lock washers flatten out. Then stop. If you overtighten them you will damage the u-joint.
  9. scooper77515
    That is the way I used to do mine. it ended up being around 10-15 ft/lbs.
  10. tody
    tody Member
    cologne, germany
    :huh: why don't i get it? obviously some kind of pun, right?
  11. baddad457
    x2 On the axle bolts. On the U joints? A little looser. A 5/16" NF needs to be around 25-35 ft/lbs. But I've never torqued these to spec. Just get em tight as you can with a 1/4" drive ratchet and socket
  12. scooper77515
    You speak german, does anything sound like "gooden taht" that translates to anything, or are we just making fun of the fact that you can say it with what we consider to be a german accent to make it sound funny (in our ears, at least).
    Regardless, it may be politically incorrect for us to make fun of the german language...:huh:
  13. tody
    tody Member
    cologne, germany
    no problem in making fun - i'm used to that. lived in the uk for half a year, that was pretty hard stuff :biglaugh:
    but i got it, it *might* sound like "guten tag" which means "good day" as a greeting in german. but the pronounciation doesn't fit too well, so i thought it might be something different :thumbs2:
