dome lamp questions?
Discussion in 'Technical' started by maverick7072, Jul 11, 2022.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    im ready to place a new bulb in my dome lamp an dpossibly replace both domes door jam switches .when i got the car i couldnt get the dome light to go off so i removed the bulb ,so the next day i realized the passenger side dome light switch wasnt even there , so my question is will that cause the dome light to stay on if one of the door jam switches is missing or not functioning properly? kinda woul dlike to find out before i spend any cash thanks
  2. Acornridgeman
    Wisconsin
    Missing switch keeps the circuit open, so no light from that side. Possible to have a broken switch that would keep it on but unlikely. The other option is the headlight switch rotated into the "dome light on" position. Did you check the headlight switch?
    RMiller likes this.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    no i havnt thought about the headlight switch but i will have to replace the dome light bulb first since i dont know what i did with mine lol
  4. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    It doesn’t sound love your switch problem, but one upgrade I did to my 72 was instead of a bulb or led bulb replacement I got a LED light panel and wires it it. They are super bright if you think you need extra light in there.
    71gold likes this.
  5. 71gold
    :thumbs2:
    I like the LED panel idea. I've seen a lot of the lens yellowed or burnt from the stock bulbs, mine had one of those lens.
    jasonwthompson likes this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    Led in the dome light is the way to go. Uses less current, and never gets hot...
    Krazy Comet and mojo like this.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Like Frank said, incandescent can burn and/or yellow the lens. I used what they call a Festoon led, works great.
  8. mojo
    You have a part number for the dome LED?
    71gold likes this.
  9. dyent
    dyent Member
    vancouver bc
    David
    mojo and 71gold like this.
  10. jasonwthompson
    Carrollton TX
