Door Glass/Window holding clips for 72 comet.
Discussion in 'Technical' started by lpolson07, Oct 30, 2011.
  1. lpolson07
    lpolson07 Member
    Des Moines
    76 Maverick, 72 Comet
    Alright here is my issue. I purchased a 72 Comet that had both drivers side door and rear quarter glass broken out. I was recently able to pull parts off a 69.5 Maverick to include the quarter glass and door in its entirety.
    I replaced the quarter glass portion no problem.
    The glass I removed from the Maverick door is correct for my Comet door, holes line up and everything is good. The problem i am having is with the clip/fastener that holds the glass to the bar ==O=========O== inside the door. It requires two fastners and I cannot find them locally.
    I was able to salvage one from my origional door but I didn't want to risk breaking the glass to save a fastner.
    I tried Oreillys first - super unhelpful.
    Then Advanced Auto Parts - equally unhelpful
    Then Napa - the guys there were helpful and looked through a book to compare the one I dad to ones they had available but they couldn't find a match. Finally sold me something they said should work but definately didnt.
    I was disappointed I couldnt finish up this task completely today but I don't want to rig it, I need the correct clip.
    What clip/fastener do I need and where can I get it?
  2. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Try asking Craig Selvey....I have bought these from him before. He has the Factory ones.
    If Craig runs out...this place has a limited supply of Blue ones:
    I know that both the ones from Craig, and Mr G's are correct, so you don't have to worry about buying them again, and them being wrong.
  3. Craig Selvey
    Yes......I still have some. Email me directly (see below) if I can help.
  4. lpolson07
    lpolson07 Member
    Des Moines
    Hey Cactusgrabber I would just like to say that your post was very thorough and informative. I couldn't have asked for a better answer to my questions and you even provided two sources! Awesome and thank you thank you thank you!
    Craig, I will be e-mailing you later this afternoon after I am finished with work. I appreciate your time.
