Door Interior Paint
Discussion in 'General Maverick/Comet' started by Gene Fiore, Oct 23, 2017.
  1. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I am about to install my new door panels but I want to paint the textured metal part on the interior part of the doors. I want to just use a spray can. I've cleaned them and lightly sanded with 600 grit. The paint that is on there is black and somewhat glossy. I checked some posts looking for help and one said to use Duplicolor Perfect Match Black Metallic(part BUN0090)...I may have mis-read and this paint may be for the dash and not the doors? Anyway, I bought a can and did a test on a piece of scrap metal and it looks too metallic...almost with hints of gold. I'm thinking a black satin might be a better choice but I can't seem to find this color in the Duplicolor Perfect Match brand. Any ideas what brand/color I could use?
  2. Acornridgeman
    Wisconsin
    I have found the Krylon Dual Superbond to be a really nice alternative to use when a quick spray can is preferred. The factory used a slight metallic in their spray, but this Krylon comes out in just about the perfect gloss and has a great color to it. It is just right in looks, except for the lack of the slight metallic. If the factory metallic is desired - you can get that in spray cans from Mustang parts suppliers. Buy several cans as those tend to spray very thin.
    1 can of the Krylon should be enough to do 2 doors. Krylon Dual Superbond - 8823 in Satin Black - you can buy it anywhere, including Wal-Mart
    https://www.walmart.com/ip/Krylon-D... Dual Superbond - 8823 in Satin Black&veh=sem
    Gene Fiore likes this.
  3. z28th1s
    Lynchburg, VA
    I used SEM black paint on the metal portions of the doors of my '72 Grabber and the '73 Comet that I used to have they came out great.
    The paint cans are at my shop across town but IIRC the color is either called Satin Black or Landau Black.
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Rattle can?
  5. z28th1s
    Lynchburg, VA
    Yes
    I looked the SEM Landau Black is the carpet/vinyl dye that I used.
    I used the SEM Trim Black on the interior metal portions of my door. They have 3 different 'sheens' of the black (matte, satin and gloss). I'm pretty sure the one that I used was the satin.
    They carry the SEM brand at most of my local automotive paint dealers.
  6. bmcdaniel
    I just use Rustoleum satin black on everything...
  7. 71Mavrk
    71Mavrk Member
    Nevada
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I went with the Krylon Dual Superbond...here is how it looks after the two coats. New door panels go on next.
    mavgrab302 likes this.
  9. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Here's how it looks with the new panel installed.
    Acornridgeman likes this.
  10. Acornridgeman
    Wisconsin
    That seems to match the panel nicely. :thumbs2:
    I liked the way the Superbond laid down. I found it easy to work with. How did you like it?
  11. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I really liked it...laid down nice! I put two coats on it.
    Miguel Arzola likes this.
  12. Miguel Arzola
    Miguel Arzola Member
    Long Beach Ca.
    1975 maverick Grabber
    What color did you use satin black ? Can you post a picture of the can ? Turn very nice the door, ,
  13. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
  14. 71gold
    x2...Rustoleum satin black 7777
  15. fullcm
    fullcm Doug
    Michigan
    74 maverick
    I needed to paint my new dash cover and package tray along with several of the interior panels so I went to my local painters supply and they matched it and put it in a rattle can for me. It was a lot cheaper than I expected. I think the total cost was about $35 and I got two spray cans plus enough left over in a can to make another spray can if I need it. The match was perfect, can't even tell (I have a blue interior). For the match, I removed the glove compartment door and brought it into the store.
