Door panels from distinctive industries
Discussion in 'General Maverick/Comet' started by 73curtis, Jun 8, 2017.
  1. 73curtis
    73curtis Member
    ohio
    mine seem to be a little bigger than the original panels , a little to tall to fit in between groves in the door especially in the front by the window crank , everywhere else it's inset except that part , has anyone else had that happen . Both passenger and drivers fit the same way for me .
  2. rthomas771
    Got a pic? Mine fit great
  3. 73curtis
    73curtis Member
    ohio
    Mine is a 70 , what year is yours , I will take a picture tomorrow
  4. 73curtis
    73curtis Member
    ohio
    I also had to pad up the tunnel so the carpet would fit good
  5. 73curtis
    73curtis Member
    ohio
    The panels look great but the fit wasn't as good as I had expected, maybe the 70 door is slightly different, but I dought it
  6. rthomas771
    I have a '74
  7. 73curtis
    73curtis Member
    ohio
    it's hard to tell from the pictures but it fits in the back but not at the front ,just too big and you can't make it any smaller without removing the material
  8. 73curtis
    73curtis Member
    ohio
    72 panels don't fit very well either, If you want them to fit upfront they hang over the back and if you get them even in the back then you can't put your window crank and without Rubbing a hole through it I would think
  9. Craig Selvey
    In looking at the pictures....everything looks normal to me.....just like the factory fit them. The NEW panels are "thicker" but they were probably that thick 40 years ago as well.
  10. rthomas771
    Like I said, mine fit great. Are you sure you put the clip in correct? Are you using the factory clips? Do you have the plastic escutcheon behind your window handles so the handle doesn't rub the door panel?
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Looks to me like the clips were put in wrong.
  12. 73curtis
    73curtis Member
    ohio
    I put the original panel on top of the new ones and they were a little smaller than the new ones on both cars , I ended up pushing the panels toward the back a little so the window crank wouldn't fit so tight ( I do have the plastic washer behind the crank ) but I couldn't use all the clips, (original clips) and the panel hangs off the back a little more than it should ( even with no clips on the panel) , don't get me wrong I'm happy that they make them , and I'm happy with how they look , overall picture looks good, also had the original seats recovered, the guy did a great job.
  13. 73curtis
    73curtis Member
    ohio
    Do you have a picture of the front half?
  14. rthomas771
    I do now! lol
    M.A.V. and jasonwthompson like this.
  15. 73curtis
    73curtis Member
    ohio
    Your right they do look perfect
