Drag link hitting stater
Discussion in 'Technical' started by Aaron.STL, Mar 31, 2015.
  1. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    I recently purchased a 76 maverick that was original a straight six car. The previous owner did a 302 swap from a 74 mustang II. I noticed the drag link hitting the starts. Is there a different drag link needed for the 302 setup or a smaller starter? The car has a manual steering setup.
  2. Krazy Comet
    I can't visualize how the drag link could hit the starter, normally it's at least two or three inches below... Link is same for 6cyl or V8... Possibly does the M-II bell mount starter lower than std bell(assuming it was used)??
    Gotta picture??
    BTW there are smaller late model starters but should not be needed, something is seriously mismatched...
  3. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    I will post a pic when I get home. Is it possible the wrong motor mounts where used?
  4. Krazy Comet
    I suppose anything is possible, does the pan seem to hang low??
    A stock pan should be about even with the front crossmember...
  5. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
  6. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
  7. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    I have know idea why the second photo is upside down. I'm currently replacing the steering gearbox.
  8. Krazy Comet
    Well I dunno, any chance it maybe has incorrect idler arm?? I have two finger width of clearance between link & starter... I am using a newer gear reduction starter but at that point there is less than ½" difference in the two types...
    There's much greater clearance than pict suggests...
  9. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    Thanks for the help. I will look into the idler arm and
    post after I install.
  10. fredee
    fredee Member
    South MS.
    1971 comet
    It's rubbing across the oil pan also. May need some thick washers between the motor mount and block to raise the engine up a little.
  11. 71gold
    the drag link may be bent...
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I owned a Mustang II V8 car. The oil pan and manual bell housing are application specific to the Mustang II if memory serves. These factors could very well be associated with your problem.
  13. Krazy Comet
    True, someone may have raised car with floor jack under linkage...
  14. Paul Masson
    1971 Grabber
    IIRC, MII has a 141-tooth flex plate and the Maverick has a 157-tooth. Looking at images on-line of the two different block plates, the MII starter seems to hang down lower past the crank centerline. This would place the starter that much closer to the steering components. Just my two cents...
    Aaron.STL likes this.
  15. Aaron.STL
    Aaron.STL Member
    Point Mugu CA
    1976 Maverick 302
    I checked the drag link and it's not bent and the idler arm is correct. That's great info about the mustang II power plant. I will hunt down a smaller starter. Thank you to everyone for the help.
