Drilling out axle for 5 lugs
Discussion in 'General Maverick/Comet' started by pachecoj, Mar 23, 2008.
  1. pachecoj
    pachecoj Member
    RI
    1971 Comet
    I have a 4 lug car. To do the 5 lug conversion it seems like most people swap everything over to 5 lug.
    I was planning on doing this but a friend of mine asked why I don't just drill out the existing drums for 5 lug. I thought about it, and it makes sense, has anybody done this?
    I was thinking of popping the axles out and dropping it off at a machine shop to do it, what would be involved? Would they have to fill in the holes where the 4 lugs were and then re-drill or something?
    Jason
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    i am a machinist so i drilled mine out for 5 x 4.5 . and yes you need to plug the holes.
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I have a 5 lug 8", drum to drum, I'll let go for $100, but you would have to come pick up
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    A 5 lug rear end is much stronger than a 4 lug. You'll be better off going with the 5 lug setup. .....but, it is your money. Good Luck Dude(y)
  5. Jamie Miles
    Alto, GA
    I've had a few
    What makes it stronger?
  6. Craig Selvey
    You still have to convert over to 5-lug brakes unless you also redrill your old drums.
  7. tim keck
    sharps chapel,Tn
    Not only do people change over to 5-lug for more wheel choices,but the 5-lug brakes are much bigger than the dinky little 4-lug brakes.If you're gonna drive it you need to be in at least the same neighborhood(let alone ballpark)as the cheapest little econobubble out there today:rolleyes:.
  8. hotrod-daddy
    hotrod-daddy Member
    5 lug vs. 4 lug
    In my opinion........The 5 lug axles are made from a stronger alloy. Many other parts like the bearings are more HD:thumbs2:
  9. stmanser
    Davenport, Iowa
    why would anyone want to drill out the drums... brand new drums arent that expensive, or you can find the drums on just about any 8" ford rear end and i am sure a junkyard would let them go for $5 a piece, or less
  10. mavmike72
    mavmike72 Member
    louisville kentucky
    the reason i did it, it didnt cost me anything to drill them out and i was allready at work, so thats why i did it.
  11. pachecoj
    pachecoj Member
    RI
    1971 Comet
    I didn't mean drill out the drum, I meant drill out the flange at the end of the axle for 5 lugs. I would obviously get new drums.
    My main point is trying to figure out whether I can just pop the axle out, drop it off at a machine shop, and have them drill it for 5 lugs. Rather than swapping the whole rear.
    Jason
  12. Craig Selvey
    I don't think you will find 5 lug drums that will work for what you want to do. You need to verify that first.
  13. Dave B
    The 5 lug rear ends are 10 3/4" drums, are the 4 lug's the same? You would think they would be smaller??? Although, I could be wrong..... and if they were smaller, wouldn't the backing plates be wrong? I could see if you were a machinist, and could do it yourself and all, but it would be a shame to have the axles done then find out you can't get drums to fit? I've never had a 4 lug car, so I don't know. I think Craig knows!!
  14. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    I have a 1976 Maverick Stallion, and 85 More Mavericks and Comets in Inventory.
    What size differential do you have,,?
  15. Jamie Miles
    Alto, GA
    I've had a few
    I don't know the specific numbers, but the drums on the 4 lug rear out of my '72 were definitely smaller then the '74 5 lug rear I put in it. It was an obvious difference to the naked eye. Not only smaller around, but the drums and brake shoes were more narrow on the 4 lug.
    A '71 Comet would have an 8 inch.
