Driveshaft help
Discussion in 'Technical' started by 390S302, Jun 23, 2009.
  1. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    I have been away for awhile. My comet has big vibration when going about 55-60 mph but levels off at speeds greater than 65 and up (just doing some testing) around town speed around 25to 50 it's fine. I guess the question is does this sound like a slightly bent or out of balance driveshaft or something worse?:hmmm:
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Sounds like old, dry u-joints. Replace them before you lose your driveshaft and note that the front and rear are different sizes.
  3. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    i'd definatly check the u-joints. my car had vibrations at different speeds and i pulled the shaft, opened the caps and the needles were destroyed and all over the place inside
  4. don graham
    Most of the problems I've had like that are because of a tire seperating. Just replaced 2 on my Montana 2 days ago.:)
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    for me it was the trans mount. i replaced the u joints and checked the drive shaft, all were good but it still vibrated from 50-60. once i replaced the trans mount it was smooth as silk again.
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I assume you've ruled out wheel imbalance.
  7. 390S302
    390S302 Member
    Brand new u-joints and needle bearings new tires as well
  8. 390S302
    390S302 Member
    all weights still on wheels
  9. Mavaholic
    When its vibrating the worst, kick it into neutral and see if it remains. If so, pull the drive shaft and get it checked for straightness and balance.
  10. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    You may have lost a weight off the driveshaft.... Can you pinpoint where the vibrating is coming from?
  11. Mavman72
    Improper pinion angle/trans tail shaft angle will do it also.Especially if you have swapped the engine/trans combo or rear axle recently to something not common in a mav...like an FE motor and a C-6 trans.Check all the other things first...
  12. sierra grabber
    northern nevada
    mavman is telling you why my trans mount made it vibrate. when i pulled the old one it was worn to where the bolts were almost half an inch to the passenger side off. this caused the tail of the trans to be off by over an inch. the mount is about $50 and mostly easy to replace. i did the u joints and tires first then had my drive shaft checked (which ended up being straight and balanced)
  13. scooper77515
    This is one of those fun ones...trying to track down a drivetrain vibe.
    Funny thing is, it is good for you. You end up replacing a BUNCH of worn out stuff before you finally find that it was a combination of ALL of those items...:rolleyes:
    I ended up doing a driveshaft balance, new u-joints, new tailshaft housing, bought (but didn't use) pinion angle shims, balanced rear wheels, I think there was more but it has been a while, and I don't remember what else it was.
