driveshaft to short
Discussion in 'Technical' started by 71_Maverick, Oct 13, 2007.
  1. 71_Maverick
    71_Maverick Member
    michigan
    does anyone know what over driveshafts fit the maverick. or if you can get longer yokes.
  2. baddad457
    I've got yokes in two lengths, the driveshaft in my 77 Comet was also too short to suit me. They yoke was only engaging about an inch of spline in the transmission tail. I swapped to a longer yoke I had from something else, I don't recall what it came from though.
  3. 71_Maverick
    71_Maverick Member
    michigan
    im in the same place that you were, mines only in about an inch but i don't know what has a longer yoke that i could use??
  4. PaulS
    If you get the long yoke be sure that the splines actually engage further. Some of the long yokes have the same length splines and the front of the yoke is just there for transmissions that have the tailshaft bearing in the case farther. (63 galaxy with the "Cast Iron" Cruis-o-matic used these)
