Drop Motor mounts for a maverick?
Discussion in 'General Maverick/Comet' started by superlead76, Mar 26, 2011.
  1. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    I just got my 347 in the 72 grabber last night and due to the height of the Vic Jr. And the Holley 750, low and behold....the damn hood won't close. Does anyone make drop motor mounts for a maverick? I don't want to lose the grabber hood. Btw.....the hood closes with the air cleaner off. Lastly, there is a 1" spacer under the carb. I'm trying to keep that too for performance. :) I guess I want it all! Haaaaa!!! Thanks guys!
  2. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    try a drop base air cleaner
  3. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Like he said, lowest drop base air cleaner you can find. How tall is your filter?
  4. Dave B
  5. strokermaverick
    strokermaverick Member
  6. scooper77515
    Lower and further back? Hmmm...that should help with header fitment at the shock towers. Not sure how it would affect headers at the other near-touch points.
    I would like to go back and down a bit.
    What about pinion angle and drive-shaft length?
    how far "down and back" are we talking here?
  7. 71gold
    didn't know it was...:hmmm:
  8. scooper77515
    Get rid of the spacer. it doesn't help that much. If at all. And may be all you need to clear the hood.
    when you are trying to close the hood over a tall engine, 1" is a LONG WAY!
  9. jmgford
    jmgford Member
    Iowa
    I have the same combination, without a spacer, using a huge stock air cleaner with a rubber seal on it. Runs 11.50 without a spacer. Don't know if it would be faster with one, but I can live with that.
  10. Joe Dirt
    It does sit lower, exactly how much I couldn't say
    im also running a vic jr with a stock air cleaner base with a 5" filter and I have about a 1/2 till it touches my 1" shortened boss 429 scoop
  11. Joe Dirt
    I was able to use the stock trans crossmember
