Drop Steering linkage or R&P
Discussion in 'Technical' started by Clean70, Jan 9, 2006.
  1. Clean70
    Clean70 Member
    Minnesota
    I have a 1970 with manual steering and I am doing a non-standard engine swap and have clearance issues between my starter and the steering linkage.
    Did Mavericks ever come with a different linkage set-up? Or, are there differences between the power assist and manual as far as geometry and pittman arm length?
    Does anyone know if pittman arms from other ford vehicles will fit the manual box? A couple inch drop and some remorking of the geometry would take care of it?
    Or, has anyone completed a manual rack and pinion conversion?
  2. Craig Selvey
    What kind of engine are you trying to put in? That might help.
  3. okibono
    okibono Member
    cali
    I am gonna go w/ a Omni rack and pinion setup...save some weight, too!
  4. Mavaholic
    Oh oh, cant waite to hear this.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    So your pitman arm is hitting the starter?
    The V8 has the starter on the other side of the engine.
    No wonder you are having issues.
    Dave
