dual carb intake
Discussion in 'Technical' started by Jap901, Mar 8, 2006.
  1. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Hello I was thing of maybe going with a dual carb intake (not tunnel ram)do any of you know if it will clear a stock grabber hood?
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    depends on the height. if the front carb is at stock height of the original center 2 barrel, you should just have to worry about the air filter. anything more would probably require some measurements.you might want to buy some styrofoam and place it behind the dizzy, then shave it down till it just clears the hood while sitting on top of the manifold. that will tell you exactly how much room you have to work with for the whole assembly.
  3. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Yes I Have A Edelbrock Set Up I Tryed It On The Car And The Stock Hood Cleared
  4. Maverick Man
    California
    if your going with a the one they offer that is a knock off shelby one (high rise).. it will work if you run really small air filters. but to me, what's the use of a small filter if you trying to stick that much air down it. i never understood why guys that put these carbs systems on their cars and put some puny 1/2 to one inch air cleaner on them. :huh:
    i had a duel set up with 390 carbs on it... i ended up selling it. to me it was not worth the time or effort never less the money.. you can get just as much out of a single as the duals... just the duals look really cool ;)
    oh and as far as what i have seen the grabber hood has no more clearance then a stock one.
  5. bmcdaniel
    I always liked the 3x2 setups. Normal driving just runs on the center carb, stomp it down and all three carbs suck a lot of air.
  6. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    I like the 6 pack also but there hard to find.
  7. bmcdaniel
    There's a couple aftermarket companies that make them.
  8. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    I've always wanted a 3x2 setup for my maverick...maybe one of these days...
  9. bmcdaniel
  10. Mavaholic
  11. bmcdaniel
    That is nice, but $1870?!!! :49:
