Dual exhaust route
Discussion in 'Technical' started by 351wmav2, Dec 5, 2006.
  1. 351wmav2
    351wmav2 Member
    Hermiston, oregon
    71 maverick
    I am going to be instaling Dual exhaust on the mave here soon instead of the dumps before the axle, so i need some pics fo your dual exaust routes over the axle, thanks guys
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    here is mine. hope this helps. i no longer have the air shocks on.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    them tires arnt BALD are they:evilsmile :rofl:
  4. fan2488
    fan2488 Member
    spring,TX
    yes they are. have new ones now.
  5. Maverick Man
    California
    heres some more images and angle of them over the axle
  6. Thack
    Thack vision advicator
    Moreno Valley Ca
    Hey Derrick your spring doesn't hit that.................or is that the trailer queen :D
  7. 351wmav2
    351wmav2 Member
    Hermiston, oregon
    71 maverick
    what size exaust are you guys running? also can i get some more pics of the front exaust where it mounts to the headers? what is the advantage of using a H pipe?
  8. scooper77515
    Scary thing is...I bet you Fan2488 did that all by himself, in the garage, with basic mechanics tools...Look at those smooth bends...DAYUM!!!
  9. fan2488
    fan2488 Member
    spring,TX
    yes i did it my self. but i had to modify a mustang exhaust. mine is 2 1/2" mandrel bent.
  10. PaulS
    The advantage to using a properly tuned "H" or "X" pipe is that it broadens the torque and Hp curves. It adds a pulse to the harmonics that can scavange the exhaust from the cylinder (adds a low pressure (vacuum) signal as the exhaust valve closes which makes the intake charge enter faster which fills it more completely. more charge = more power!
  11. maverick75
    A cool trick to find out were to put the H-pipe is to draw a line with a crayon...were it stops melting is were it goes.
    I'm also going to route the exhaust like derrick except mine will go all the way back..like old camaros.
  12. eddie1975
    Martinsburg, WV
    sold
  13. PaulS
    Most small blocks do fine on 2 1/2" tubes. If you try to put 3" tubes on the Maverick you may have some difficulty getting by the fuel tank on the left (driver's) side.
