Dual Tailpipes?
Discussion in 'General Maverick/Comet' started by ZaksComet, Jan 31, 2014.
  1. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I currently have no tailpipes so everything dumps out just before the rear axle from my flowmaster 40's. I was wondering if anyone makes a set of rear exiting tailpipes that will fit a 72 Comet? I thought I had seen someone say they used these before http://www.summitracing.com/parts/flo-15807/overview/make/ford
    I'm really tired of blowing dirt up onto my freshly cleaned black paint :mad:
    Open to hearing what everyone has to say! I'd like to go with 2.5" pipes
  2. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i had my duels done at an exhaust shop, it was alot easier, i didn't want to worry about clearance issues. i paid $220 or so to have my whole exhaust done, i went with dual glasspacks though
  3. CaptainComet
    While you are at it, you might look into having your pipes run outside the frame rails if someone is bending them for you. It is a little tight, but someone with some skills can get it done. I like the way it looks a lot better than pipes that are inside the rails. I would ask for referrals from other local car guys if you don't already have someone in mind.
    I wish they were lit a bit better in this shot, but it will give you the idea.
  4. 55crownvic
    55crownvic Member
    colorado springs
    I kinda like these.........
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's best to just have an exhaust shop do it for you.
    No one sells tailpipes specifically for a Maverick.
  6. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I really like that!!
  7. Krazy Comet
    Yep meee tooo...
  8. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    to get more clearance on left side ..is it best to put a narrow gas tank in from an old mustang ?
  9. rthomas771
    Old Mustang tanks are a lot wider than a Maverick tank.
  10. z28th1s
    Lynchburg, VA
    My tail pipes are 3" (along with the rest of the exhaust) and tuck down behind the rear tires. It was custom bent by a friend of mine.
  11. 71gold
    or center your stock gas tank...:thumbs2:
      File size:
      180.9 KB
      36
    AllOut84 likes this.
  12. ray-g151
    ray-g151 Member
    Hatboro, PA
    1971 Maverick 412w , 1969 Cougar 427w, 1973 Maverick 306w
    If you use a set of LX Fox Body tailpipes and twist them in there, you can have them exit just behind the tire. I did this years ago when I had my 2.5 exhaust. You would need to get the tailpipes to go over the axle then go between the spring and the lower quarter. Before welding them up, I cut the tailpipes on angle, so they were flush with the bottom of the quarter. I may have an old pic around, it's been about 10 years since I had that exhaust. It will look like the pic above, but less bending.
  13. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    Hey what is that valance off of? We want to do exactely that but didn't know there was a valance already precut so to speak, while we are on it and not to hi-jack your thread OP but it seemed like this fits: We are currently running Magnaflow's with end dump's, idling sounds nice BUT stomp it and OMG it's loud, what muffler's would ya'll recommend that sound nice at idle and while letting you hear it don't get so loud AND has anyone utilized the cut-outs with or with out in cab lever to open them? Thanks in advance
  14. z28th1s
    Lynchburg, VA
    There is no rear valance that is cut out for the exhaust. All the Mavericks and Comets came with single exhaust. The one that you like was custom cut to match where he wanted his exhaust to exit. It does look good and looks as if it might have originally came like that.
  15. SamsDad
    SamsDad Member
    Little Rock, Ar
    Thanks, now I know what we need to do, does look dang good
